I have a problem to end/disconnect the call. While talking and having the phome close to my ear the screen is off/black. Then I want to finish the call and take it in my hand the screan should turn on again. It doeesn't happend. It causes more problems when the person I'm calling to, does not answer and I want to disconnect without leaving a massage. It warked before. After last updates it stoped. Could you tell me that causes this?
Have you checked if the sensors are working correctly in Xperia Diagnostics? If not, you can give it a try.
