I find some problems when using my Z2 with the latest .232 fw. SystemUI.apk has some bugs. The brightness slider and the color of the background of the pull down panel doesn't change when the theme is changed. Also, the navigation bar goes back to stock style in some immersive apps like Sony Album. Some screenshots can be found in
http://forum.xda-developers.com/crossdevice-dev/sony-themes-apps/mod-theme-accent-systemui-navi-butt... .
What's more, there's a gap between the signal and battery indicators, which is ugly for me and didn't appear in early fws based on Android 5.0.2. In Settings - Power management - Power usage (Something like that. I use simplified Chinese as system language.), the number showing the power left in the first line misses a % after it. And when I set font size to small, the size of Screenshot and Screen recording in the power-off menu become bigger. Those may not be all, and I'll add more if I find more. Hope that you can fix those problems.
