I have a xperia arc s Running on ics....The problem is with battery sign on the display its shows charging but the usb is not connect....plus when i connect to the pc using mass storage mode when i try to eject the mass storage wont eject i had to restart my phone when connecting to the pc
With the information provided it sounds like you may have a glitch within the device, I suggest that you perform a software repair to resolve these issues.
1. Before you start you have to download the PC Companion software and install it on your PC.
2. Once installed on your PC, double-click the PC Companion icon on your desktop to start the update. Note! For some models you will be prompted to do a backup prior to the update and then restore.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
