Phone is not responding
sp3457
When I update my phone to 5.1 my is totally dead. Firstly it automatically stop at 50% charging and now it is not starting and I don't know what's happening to my phone.
5 REPLIES 5
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
sp3457
But my decice is not charging above 50% and it is not starting as well
_alexdon_
It does not need to start. Just make sure you keep it connected to wall socket for 3 hours.
alexdon
sp3457
Yes when I connected my device to wall socket the red light is continue blinking...
_alexdon_
When you connect to charge, make sure to force stop it using the methods presented in my upper post.
alexdon
