Overheating problems with Xperia Z2
Lyudi
I bought my new Sony Xperia Z2 in Bulgaria on the 27-th May. I tested the camera in 4K video and normal mode. I noticed that the phone is getting hot after making some photos and video. When I recorded a 4K video the camera switched off after only 2 minutes with massege Overheating! I saw that many others had the same problem. My question is is there a chance to fix the problem. Can I return the phone and change it with another one?
159 REPLIES 159
Mih
@Z2inQld...hmm, interesting... I haven't tried a different app for photography.
My heat issues got 80% better after factory reset. I also got rid of the cases I tired with the phone, as I too suspected that they aren't helping with the heat dissipation.
My phone really overheats with photography anymore, but Waze and screen on continuously does bring the temperature up (67C CPU temp) unless I keep the phone out of the sun and reasonably ventilated (while using aforementioned Waze).
The glass back is nice-looking, but glass has bad heat dissipation qualities. I suspect that's the main issue causing heat.
What instances of incompatibility did you encounter?
Mih
"Rarely" overheats with photography, not "really"
143teja6
Hi sony will replace my mobile without taking any cost if that heating issue was there
Prashanth123
My Sony z2 is getting heat with normal usage only.. I have updated the phone to lollipop,. But the problem doesn't resolved. What should I do
Mih
Try downloading CPU monitor from the Play store and see what uses up all the CPU to warm up the phone.  Maybe a stuck app or something
Isac
My XPERIA Z3dual running LOLLIPOP keep warning me for rising temperature as soon as I switch on the camera. Could you solve this....?
manojgurung
My Xperia Z2 heats up after taking few pictures even in superior auto mode. I m having this problem after updating my phone from kitkat to Lollipop.. Any help please?
Sachin83
Any solution from Sony?
Irslan
I also have the same issue regarding overheating in xperia z2...they become heated while using a normal mobile like chatting or calling to the next person..i thought sony have these problems in all z series...all please be aware to buy sony mobiles..
JoseTiago14
I have the same issues, i can't use the camera for video or taking pictures on the beach without receving the overheating message. This is really annoying/problematic as i bought this phone for it's camera specifications. I already had smartphones from other brands, like samsung or Huawei and i never had problmes. What's the purpose of having a 20 MP camera if then i can't use it on a sunny day.
On my last Vacations i went to Mexico and i couldn't take more than two pictures in a row without receiving a overheating warning message. Is the second time i send my phone for customer support, let's hope they can fix it or replace, because on the first time they haven't done nothing.
