Otg support stopped
Divharwani
Otg support stopped
After software update in sony xperia m otg is not supporting. Please help
Tags (1)
7 REPLIES 7
profile.country.PH.title
MarlonUk1
hi, can you give more details regarding the problem?
what OTG device are you trying to connect?
can you try to connect the OTG while you are on safe mode?
try to perform a software repair using Xperia Companion
Divharwani
Yes I have tried in safe mode even searched on google but did not get the solution. I am not able to connect pendrive through otg cable and also any otg pendrive.
MarlonUk1
have you tried to use the pendrive to another phone? does it work?
https://www.youtube.com/watch?v=jKpNQoCtrTo
Divharwani
Yes i have tried same pendrive on other phone it works on other phones
MarlonUk1
hmm. but when you connect the pendrive does it give an indication that it receives power from the device? (led on)
I can't suggest anything else but to try software repair using Xperia Companion or have your phone checked at your Local support
Divharwani
No nothing
Didrik
Enthusiast
Hi @Divharwani,
Welcome to the community!
I'm really sorry to hear about what you are experiencing.
Was there any change after the software repair as @nolramlb suggested? If not, have you been able to try connecting a (for example) USB mouse or keyboard to your phone? Have you tried rebooting your phone with the OTG-adapter and the accessory connected?
Should your phone still not recognize a computer mouse and/or keyboard it sounds like this might be related to hardware rather than software. If the above does not help I would advise you to have your phone sent in to be examined by an authorized service centre, for information on how to proceed I'd recommend contacting your Local support as they will have more information on local service procedures in your area.
Keep me updated! Slightly_smiling_Face
