Hi Team,
After Xperia M2 Lollipop Update 5.1.1 build 18.6.A.0.175 I am not able delete the SMS.
When tried to delete the SMS it says "Conversation deleted" but the sms is still there only.
As suggested in the one of the previous forum asked me to try the same in "Safe Mode". I have tried the same but its not working for me in the "Safe Mode"
Hi @Krish0117,
I suggest that you change your default SMS app to Hangouts temporarily, can you see the message and try to delete it in that app?
You can set the default SMS app if you go to Settings > More > Default SMS app.
Hi Chris,
Thanks for the reply.
I have tried putting Hangout as the default sms app.
But its actually not working properly for me.
Could you please advise.
hi Krish0117 ,
[Instead of long press & delete] did u tried to delete the coverstation by Messages->Menu[3dots]->Delete Coversations and select the message coversations and give delete... ]
and, if it didn't work try ->
Download and install "history eraser" by INFOLIFE LLC and try to delete the messages...
Thanq for trying... 🙂
Well... Krish0117...
Thats unfortunate... 😕
Then, there's a one thing u can do... if u have so much of messages u dont want to lose.. then, try MYPHONEEXPLORER by fjsoft [PC Software] and, backup all the messages then, reset message backup... or try deleting them thro MyPhoneExplorer...
Thanks for giving it a try...
@Krish0117 You could make a backup of your messages using the pre-installed Backup & restore app in the phone, then erase all messages using the app suggested by @AshwinRuffian and finally restore your messages from the backup and try to delete again.
