Network problem
pradnya_chaphe_
Network problem
HI, I have bought Sony xperia P a month ago .I am facing network problem every morning when m going to  cal first time....everyday my mobile is not get  connected when first time i cal .  I have to restart it then it will work fine .....  Is anyone facing the same problem ? or  anybody having solution for it...
4 REPLIES 4
jackxperiaP
do a factory reset and try ur problem is solved ...
profile.country.RO.title
_alexdon_
What are your network settings?(2G,3G or 2G/3G)
alexdon
pradnya_chaphe_
network setting is 2G  i.e GSM only
_alexdon_
You have a good network coverage?Usually,GSM only has the best signal.There may be a problem with your antenna.Either take the phone to a sony center,or repair and reset like jack told you.
alexdon
