Hello,
i updated my Neo with PcCompagnon but after i needed to use the "repair" function.
Now, the phone as lost the initials internet parameters... so internet doesn't work...
I tryed to add APN point manually but this is not possible. When i want to save the APN, nothing happen !?
I tryed to get the parameters by sms but the phone don't want to install them !!!
No internet and can't create an APN point : what can i do ??
Thx for help.
Have you tried getting the handset to auto install the settings:
Main Menu > Settings > Sony Ericsson > Internet Settings > Accept. (Make sure you have Data Enabled)
Thanks. But, yes, i already tried...
so -> "parameters download failure. Retry ?" -> yes (5X) -> "go to www.sonyericsson.com from your pc to find the good settings"...
Yes, data is enable but it doesn't works.
I also tried with an APN application (from the market) downloaded with a wifi connection. No aim ! Impossible to create the APN and connect !?
I have also used update center to restore again : always the same, no APN (not with sony, not manually, not by sms, not by an application)
I had this same problem also, for me a repair to factory setting through the pc companion sorted the problem, now the only gripe I have is the fact the phone has crazy moments whilst on charge
