my xperia sp not starting :(
Mafia121
when i charge the phone ..its led keeps on glowing red and it does not start Slightly_frowning_Face ...what is the problem with it ? 😕
26 REPLIES 26
Mafia121
not yet Slightly_frowning_Face
Nayan234567
I live in Bangladesh and here's no such authorized agent here.
Nayan234567
I found over the internet that many people has the same issues with other devices! Could you please tell me what's the correct procedure to make it wokring again????
RuchRha
Try using sony update service it will surely work.
Nayan234567
Tried it too but it can't find my mobile connected via USB Slightly_frowning_Face
RuchRha
Do you use the correct method to connect your device? turn off the phone via back panel wait 5-10 seconds, open sony update service and select SP it will ask you to connect your phone before connecting your phone keep your USB plugged into PC then press down volume button on SP and while it's pressed connect the usb into device it will recognize it.
Nayan234567
Did it... But it can recognize my phone connected via USB Slightly_frowning_Face
dozcinko
try connecting the usb at the back panel of your pc... and remove your sdcard if you have...
Nayan234567
I am using laptop.. but did that too.. The main problem is when I connect it to charger its showing the Red LED but its not found in PCC,SUS,Flashtool,Emma by Sony... It ask me to connect my device and I connect it but it does not recognize... Done it by pressing volume done key,power key every method,but it just stuck in connect you device option and cant detect my device even I connect it Slightly_frowning_Face
@Nayan234567 have you unlocked the bootloader/
