My wifi use to turn on and off fine I would turn it on at home to avoid data the last few days it won't do nothing WiFi won't turn on go so settings swipe it from off to on it turn light blue but doesn't come up tried turning off phone to reset still same why won't it turn on
@shagy959 @Thethirteenth could you both try performing a system repair as below
Performing a system repair using PC Companion will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
