Unlike Kitkat, my phone heats up very fast. I just like browsing my facebook for 30 mins and I can feel the heat from my ringke fusion case.
I thought updating my the firmware yesterday will solve the problem but still no chance.
I joined a group of sony users here in Philippines and they said I can have more battery life if my stamina mode is off. In other words, it is not working.
Even after the firmware update.
Any thoughts/suggestions about this?
If you use your device to talk, transmit data, or play games or music for an extended time, the device may get hot. This is normal because in these conditions the device uses more power than usual and therefore generates more heat. If your device gets hot after only light usage or for no apparent reason, i suggest that you make sure you use original charging accessories and follow Phy's advice.
@Jeff14 If you would have used the search button,you had known that the both of your posts have already been posted as questions in this large thread:
/t5/Xperia-Z3-Compact/Feeback-Lollipop-on-Z3-Z3-Compact/td-p/959223/page/14
Please take a look there.
