Micro USB Position faulty
shir
1] When you are charging the phone on stand - one cannot insert the USB flash drive because of poor ground clearance
2] Even if you are not charging and want to watch videos from USB flash drive  you need a wooden block - so that USB flash drive
has got clearance from bottom.
3] One can put the longer side up- but the phone balalnces itself on power button on a magnet.
My suggestion is put the MicroUSB slot on shorter sides.
2 REPLIES 2
Thommo
Genius
Not sure what USB cable you are using but the one I was given with this phone is angled meaning there is not clearance issue - MHL cables, some of which also have angled connections or an adaptor or coupler can be bought cheaply that is angled
shir
Thanks for your reply.  I was talking about the Micro USB pendrive. MicroUSB  slot and charging on stand should not be on same side. Either it should be on shorter sides or it should be on opposite side of charging.
