My battery is draining
Damoreee
Hello, I have an Xperia ZL and I downloaded the newest version of the lollipop software or whatever and I noticed my phone dies extremely quick, even when I'm charging it. I can't use my phone and charge it, and even if I don't use my phone the battery still doesn't charge properly. Please help me. Oh and my phone gets extremely hot majority of the time going almost to 50 degrees. ND I have the DU speed boosting/ battery saver app. Even before that I had the security app. Nothing works.
2 REPLIES 2
profile.country.PH.title
MarlonUk1
first you should not be using battery savers/ram managers.
the phone usually runs warm after an update, as it process alot of data in the background.
try to charge your phone to 100% then use as is. take a screen shot of the battery usage.
what apps are draining your battery most?
HAWX
Lollipop on Sony has a bug. Check this.. There is nothing you can do actually
http://talk.sonymobile.com/t5/Xperia-Z-ZL-ZR/Super-Fast-Battery-Drain-After-Lollipop/m-p/989128#U989...
