first you should not be using battery savers/ram managers.
the phone usually runs warm after an update, as it process alot of data in the background.
try to charge your phone to 100% then use as is. take a screen shot of the battery usage.
what apps are draining your battery most?
Lollipop on Sony has a bug. Check this.. There is nothing you can do actually
