I have Sony Xperia C. My device memory (0.98 GB) is almost full (73 MB free). I have not installed anything on my device memory. I transferred all the apps from device memory to SD card . I have also clerared the phones cache. Now I am unable to install apps or update apps using play store since the device memory is full. Further, there is internal memory of 1.23 GB that cannot be linked to play store so that apps can be installed there. Please help me to solve the problem. Is there a way to merge the device memory and internal storage of my phone. And it is impossible to install big apps or gamesinto my phone many times i contact customer care but no solution
* Memory comprises approximately 1.2 GB of firmware, plus 2.0 GB of “Internal Storage” for downloaded
applications, music, pictures and movies, and some application data.
Read more about memory here:
http://www-support-downloads.sonymobile.com/c2305/whitepaper_EN_c2305_xperia_c.pdf
Moving apps 2 SD is not possible on xperias.
Hi Guys!! I know low memory is a big issue.. I faced the same and luckily I got a fix to it..
Please don't.update using play store instead use another App such as mobogenie.. Believe me it worked.. Good luck.. If it does work.. You guys can write on me
I am with you. This is in fact a case of unfair practices. The problem is in the memory management module.
