Lost space in internal memory
vaiadubai
Hello Sony Staff!
I used the phone without problems until now, with many applications
shifted to the SD card.
Some days ago, switching on the phone, the applications installed on SD card
were unlaunchable: their graphical icon in the home screen was substituted
by a grey Android logo for each one of them.
In the Applications setting, I could only see the name of each process
but not the commercial name of the application.
As workaround, I noticed that, reinstalling the applications again
over the existing ones, it allowed them to function well without
losing their settings.
I didn't uninstall the applications before reinstalling them.
The applications function well but the big problem is this:
the System Data partition increased at least by 30-40 MBytes,
so the internal space usable for applications is much less of before.
I don't know where and why System Data increased!
How can I solve the issue?
I am uncertain what to do: if, for example, I root the phone,
can I find out what to delete to free up internal space?
If, for example, I pass from Gingerbread to ICS, will I find
more internal space like before or less?
An other option is to restore the phone at factory level.
I hope you can suggest me some method to recuperate internal storage:
Sony frustration!!
Best regards!
5 REPLIES 5
Rickard
From your description it sounds like the phone lost contact with the SD-card or that the folder on the SD-card that contains the apps somehow was deleted (for example if phone was connected to a computer in MSC-mode).
Regarding the lost storage, are you sure that all apps have been moved to the SD-card? It could also be updated apps that uses more memory. If you suspect that storage somehow has been lost i don't know of any other solution then a master reset of the phone.
You will have about the same amount of internal storage with ICS.
vaiadubai
Thanks Rickard for the answer,
the problem is that, although I move the apps in SD-card, the executable file
of them, namely the (*.apk) files, still reside in internal memory, while only
the applications' settings effectively move to external memory.
The (*.apk) files are in the folder /mnt/asec.
Probably, this is an Android fact we cannot change.
In my personal case, anyway, I think to have lost additional space that resides
in the internal memory, and I don't know for which purpose.
Some folders are not watchable in internal memory, probably only rooting
the phone could help.
Otherwise, could you link me a safe procedure to perform
the hard reset of the phone?
Thanks!!
Rickard
It should actually be the other way around. The app (*.apk) is moved to the SD-card while the apps data is stored on the internal memory. This is how it works in Android.
Try resetting the phone from Settings -> Backup & reset ->  Factory data reset. I believe that should be enough.
ymp
dear Rickard, i have the same problem with vaiadubai,
and i've just reset my phone but i still lose space internal phone memory.
it didn't work at all. Slightly_frowning_Face
Is there any other solution for this?
thank you
bogsky21
Dear sony i have a sony xperia c
it suppose to be 4GB internal memory but 1GB is just showing.. what can i do
i can't install any apps any more
plssss..help
