XPERIA Z2- PROBLEMS WITH APPLICATIONS - HELP
ROU
1) THE PHONE IS NOT PUT TO SLEEP EVENTHOUGH IT IS SET ON 15 SEC (OR 30 SEC, OR 1 MIN!)
2) THE CALENDAR DOESNOT GET SYNCRONIZED WITH FACEBOOK BIRTHDAYS OR EVENTS ALTHOUGH THE APPROPRIATE SETTINGS ARE DONE!
I HAVE CHECKED AND RE-CHECKED EVERYTHING. AND EVEN RE-INSTALLED THE FACTORY SETTINGS.
STILL THE SAME PROBLEM
8 REPLIES 8
1 that could be an app acting up and keeping your phone awake.
2. have you gone through the calendar settings ?
ROU
Thanks for answering.
1) How can I check that?
2) yes I have gone through calendar settings and FB settings as well.
3) I went on SAFE MODE, nothing happened Slightly_frowning_Face
Repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
ROU
ok thanks i am about to use PCC. I'll keep you posted... hope for the best :),  Thanks
Anytime
ROU
Well, I used PCC.
1) First I checked if it would go  to sleep! in 15sec. And it did but not completely. The screen just faded ..
2) Then checked the calendar/Facebood synch and it was fixed.
Then I restored my files backup:
1) the sleep mode stopped working  Thinking_Face
2) Sync still works.
Any other thoughts?
Sam
Legend
Legend
Just to clarify, when you say it just faded, do you mean the backlight was still on when it went to "sleep"?
