Please take a look here as most of the issues you encounter have been posted already:
/t5/Xperia-Z1-Compact/Lollipop-update-is-a-mixed-bag/m-p/968018#U968018
I am sorry you feel this way. Maybe you could try to perform a software repair which might smoothen things out.
I know how you feel and is the reason I downgraded back to KK - A good full guide is here just find and download the firmware ending with .157 and then manually flash it
You lost me with your blank post
With PCC
Bridge (for Mac)
Performing a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Backup before using the methods uli posted.
