Lollipop Update killed my Sony
Blogfootball
Since the lollipop Update my Z1c has been so unresponsive it is unbelievable. Slow to charge and battery life reduced.
For a flagship phone it now has unacceptably slow performance.
What can be done to fix this?
Please!
9 REPLIES 9
profile.country.RO.title
_alexdon_
Please take a look here as most of the issues you encounter have been posted already:
/t5/Xperia-Z1-Compact/Lollipop-update-is-a-mixed-bag/m-p/968018#U968018
alexdon
Blogfootball
Thanks die for the prompt response. Will do.
Whoever allowed this piece of junk to be pushed to phones should be fired
_alexdon_
I am sorry you feel this way. Maybe you could try to perform a software repair which might smoothen things out.
alexdon
Thommo
Genius
I know how you feel and is the reason I downgraded back to KK - A good full guide is here just find and download the firmware ending with .157 and then manually flash it
Thommo
Genius
You lost me with your blank post
Blogfootball
And how do I do a software repair please?
Blogfootball
Cheers bud
@Blogfootball
With PCC
PC Companion (PCC)
Bridge (for Mac)
_alexdon_
Performing a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Backup before using the methods uli posted.
alexdon
