Led Notifications not working since lollipop update
Dan_Dare74
Hi
Last week I updated to Lollipo, since then the only time the LED activates is when the battery is charging, I've checked in setting and its enabled (I've tried disabling it and re-enabling) I've also tried the same for individual apps (Whatsapp and viber) with no joy.  The notifcation bars do appear on the lock screen
Stamina mode is disabled
Build number is:14.5.A.0.242
13 REPLIES 13
Do you get any notification LED at all?
Dan_Dare74
no, its only ever on when the phone is on charge. it worked fine prior to the update
Dan_Dare74
i think i may have sorted it, in a fashion.
I had the phone on silent mode, as soon as i switched that off the led worked, however i was no wondering if there was a way to stop the vibration alert without activating silent mode?
Try this
on the homescreen > press the volume key > set it to sound > tap on the bell icon > it will be on vibrate mode, check if the LED notification work.
@Dan_Dare74
also try this
on the home screen > press the volume key > priority > settings > adjust settings as you please
Dan_Dare74
yes the LED now works. thank you.
however the phone still vibrates on notification, which isn't the end of the world i just wondered if you could stop all vibrations?
Check my second post
@Dan_Dare74
alex_ncfc
I've tried everything and still my notification LED does nothing apart from when charging. What do Sony do with these updates? Do they perform any sort of testing or quality control?!
