LED notification not working :( :(
premkiran_29
The LED light at the top left of the cell phone is not working for notification. Only works for discharching and battery charghing. Do you know how to fix this issue?? ( I have the Xperia J) Thanks
6 REPLIES 6
xperiatune
Well my top left led notification works in following cases:
Blue led: Msg received , misscall etc
Red led : battery low
Green/yellow: charging
  Do you mean that your notification ( blue led) doesnot lit up plz let me know may be i can help!
Rickard
What happens if you call the phone and don't answer. Do you get any notification about that?
crc
Hello i recently bought Xperia J and i got JB already installed.
I noticed as premkiran_29 problems with top left diode. My Xperia have only few days ~5, after 1st start diode notification worked fine (unanswered calls, sms etc) , but now after few days it flash only when phone is charging. I read on some of Polish boards that after installing JB it happens and diodes didn't work for some phones, so software may be problem.
kalleklappstuhl
Also, the led should be purple if you have an unread e-mail
Iloveeatingrais
Yes, the LED is not working properly, what to do? Help
franzu84
I recommend using the LED notification that located below your phone. It much brighter than the diode one 🙂 Download the illumination bar notification app from playstore.  Now it compatible with our xperia J.  You can assigning the colour of the LED for different type of notification, determine the speed on blinking and when it should stop.
