Issues with Z3+
Amer-K
Issues with Z3+
First of all, shame on you for removing my post on the battery problem I faced on Z3+
Issues I face with Z3+ that made me regret buying it:
1- battery drains so fast compares to Z3, even battery has a slight drop in capacity but I doubt it stays for even a whole day. It goes down up to 2-3% in 1 min even less time.
2- very annoying overheating problem even when browsing the net.
3- device does not stand for 75% of the day if LTE is on.
4- Display in Z3 is better in low light.
5- Camera shuts down in 1 min even 4k is not used.
6- problem in notification and ringing sound is back, I do not hear my phone if it rings or I get a message even the volume is up to the max. I do not know that I get a message if the notification light is not on.
7- phone is not slim at all, it is same thickness as Z3.. IPhone 6 should be 6.9 mm, when I put it next to Z3+ it is much slimmer than Z3+. When I put Z3+ next to Z3 it is same exact thickness..
Actually I see it a downgrade of Z3.. It is a minus more than a plus..
At least solve the heat, notification and battery drain probs pleasee!!
45 REPLIES 45
naveeneldose
what is that...
Juanp8910
@naveeneldose wrote:
i am a sony xperia z3+ user i am having 3 problems even after system repair
1. over heating and fast draining of battery
2. camera crash problem showing increase temperature and unable to work camera
3. when using skype microphone will not work after 8-10 minutes.so another party can not hear sound from my side
i am fedup with my mobile..better i should select htc or nexus..
welcome to the club
Gotsonyed
Hi All,
z3+ dual
Has anyone had an issue charging in car?
Due to the fact that battery drain is horrible on the phone, I have had to resort to charging anywhere I can.
While plugged to charge in car, it barely charges if you don't use it and discharges if you make a call or have screen on or stream music via bluetooth.
It is the same ports (I have two USB and one cigarette lighter US) I've use for my Iphone 6 and I have tried several cables.
Very disappointing battery life (Iphone 6 is better, that says a lot).
It seems like with the heat issues, there is a definite design defect with the phone. I suspect that the Z5 with dual heat pipes wil
not have the same issue. Z3+ owners are guinea pigs.
Class action?
profile.country.RO.title
_alexdon_
@naveeneldose Go to settings-scroll down to last section in settings. Do you have developer options enabled?
alexdon
naveeneldose
@alexdon yes is enabled
_alexdon_
Go in developer options and see if Use Awesome player is on.
alexdon
