I have same issues as everybody else.
Most annoying is the overheating problems.
I chatted with a consultant at Sony that was NOT aware of the heating problem.
He asked me to check the version number of the phone.
My version number is: 28.0.A.7.24.
He said that that version was the latest and i quote:
"That is the latest version, in this version we have limited heat generation while using some functions. Note that Xperia Z3+ is a high performance device which will under some circumstances generate extra heat while doing tasks which require a lot of processing, such as photographing. But if the issue occurs very frequently you may ask your retailer you help you in sending your device in to a service center for examination."
Bla.....
Device is now at a service center knowing that it most likely won't help.
So much money wasted!
UPDATE:
The store i bought it from talked to a Sony-guy that said:
Most likely the phone has a "pre software" installed which is causing the problems. And if one update Android to 5.02 or newer it would solve the problem....
The Sony guy also said: If you use your phone with a lot of video and camera apps it will shut down. But that is to protect the phone........whaaaaaaat???
Come on Sony, seriously?
UPDATE NEW 7. AUGUST 2015
Just got my Z3+ back from service. Still same camera problems. Can't use it to shoot pictures or videos.
Repairman mentions in his report that no issues was found and the camera behaves normally.
It's normal for the camera to shut down to cool of. Hmm...
Never ever experienced that with other phones and i guess that's to expect in 2015 where all smartphones are equipped with a very good and functional camera, even for cheap phones. But not for Sonys flagship phones.
Well, what's your opinion. Is this what to expect from a brand new flagship phone?
I shot a video with my brand new iPhone 6, just 5 minutes after getting the Z3+ back.
Link to video: http://www.beepme.dk/elgiganten/z3plus.mov
On your previous post that was removed, it was a new thread, you can continue posting here.
Thanks
Z3+, One of the worst flagsip model.
HI i have so many problems on my Z3+
1 . My phone get heat so much . even i was on the call and surfing web .
2. it get freeze all the time .
3. my all applications icona and that entire row shows under neath the bottom icon tray (Home , back, recent apps)
4. sometimes when i call someone i cant here anything or they cant here anyting but call is answerd .
i tryed reseting my phone and doing repire through pcc. and done the software update as well,
nothing working after doing software update i have reset and done the repaire through pcc as well. no luck any solutions please???
i had Xperia S, T, Z,Z1, ZUltra, Z2, Z3 never had a issue like this , please help
Your phone getting hot it's normal, have you contacted your local Xperia Care to get it checked?
Also, does this occur while on safe mode?
i didnt contact the sony yet. i seen on xda after updating to new firmware and repire by pcc thire phone are working fine no more heating issue even while 4K recording . i have try booting in safe mode its same ..
