ICS Walkman App playing through bluetooth problem!?
If I connect to my van via bluetooth and play music so it comes through the vans speakers, it's terrible! It just keeps cutting out and stuttering all the time. I know more with the same problem, Sony can you fix this issue please?!
31 REPLIES 31
Johan
Strange. I think that this needs to be tested with other Bluetooth devices as well to be able to tell where the problem is located. Do you know if you get the same bad quality when using a A2DP headset? Like MW600 or any other stereo Bluetooth headset.
Mine is connecting to the a Parrot hands free, but others over on xda are having the same problem on different devices
Same problem here
When playing music or listening Internet radio through BT-headset/loud speakers the music is skipping every time you wake up your phone, open apps, shutting down apps and so fort.
And sometimes even when you do nothing just listening
I use MW600 and Edifier BT speakers
Everything was fine before the update
Very irritating!!
I am currently sat in my van, connected to the parrot by bluetooth, but I've turned off the option for media so its only for phone calls, then I've audio jack'd my fone into the front of my stereo so its playing as aux in instead and there's no skipping what so ever! It's only through bluetooth!
Mine stutters a little but the worst part is the EQ, bluetooth sound quality is terrible now...
ricky_apriady_g
Yes, i am encountering the same problem.
While you switching apps, e.g.: from walkman app to home, home to browser, or even unlock the home screen, it keeps stuttering.
It did not happen in Gingerbread.
Could it due to the RAM consumption that is high in ICS?
luis_DR
Hi, same problem here playing through stereo bluetooth speakers. it keeps stuttering, I have a SuperTooth. so i have to use the 3.5jack cable now:smileyplain:. i play music through bluetooth every day, so you how i feel now...
I have the same problem since I've upgraded my Xperia S to ICS 4.0.4. I play music through Sony Ericsson MBS 100 bluetooth speakers, and the sound quality is very bad.
This issue didn't happen with GB.
jonathanc_
same problem for me, i am using MW600 stereo bluetooth. sounds interapted evrytime using other application. same problem with X10 when upgraded to GB 2.3. poor implementation or alocation of memory.
