I have Xperia Sola with microSD Kingston 16Gb class 10.
The problem is that when connecting to a computer, I see only the built-in memory ("Internal Storage"), but dont see SD card anywhere (Windows 7 x64)
In Device Manager on my PC i see device "Mass storage" (VID_0FCE&PID_A173) with yellow triangle (it means drivers not found, i google it but find nothing), perhaps this is reason?
At the same time i can see this card on phone via Settings - Memory and via Astro File manager (the card is showed as ext_card)
What do you advise that I could see SD Card via PC? (sd card must be inserted into xperia sola
Thank you
Ok, i download SUS, run it and perform all steps (include firmware update).
The situation the same: in Device Manager i see unknown device "Mass Storage" with sony VID,
and still to idea where to find driver for this device.
In Explorer on PC i see device "XPERIA sola" with Internal Storage (i think this is MTP protocol)
I think main question is where to find drivers for Mass Storage device.
Any ideas?
here you go
http://developer.sonymobile.com/cws/devworld/search-downloads/driver
Don't forget to mark theCorrect Answers & Helpful Answers
Thank you
With this drivers device "Mass Storage" automatically recognized as
"Sony Ericsson sa0104 ADB Interface Driver"
Try to reboot PC and reconnect phone, but still cannot see any cards except Internal Storage.
Also i try to enable "USB Debug" option in phone Settings, my PC search for drivers and find all except "Mass Storage" (it once again present in Device Manager as unknown device).
If i disable the USB Debug option, "Mass Storage" not visible in Device Manager.
try MSC
sorry, what is MSC? how i can use it?
settings -> Xperia -> connectivity -> USB connection mode
but.. i have no choose for this option.
in settings -> Xperia -> connectivity -> USB connection mode
i see:
USB Connection mode
MTP only for internal storage
MSC only for SD card
i tap on this menu item and see dialog with detailed description - no options for choose here
and option "Auto connect in MSC" always enabled
yes choose MSC you want your PC to recognize your SD card so give it a shot
Ok, i check "Auto connect in MSC" option, i see "SD card connected" via notifications, but on PC cant see any changes (
