HELP PLEASE!! my sony xpiria t is broke :(
ashf
when i try to charge my sony xperia t, it will charge for about 2 seconds turning on and showing the beginging phase of the start up (the sony logo) and showing the red led light but no matter what i do i cant get it too stay on it will always turn off after about two seconds please help
17 REPLIES 17
Thommo
Genius
Have you tried a system repair?
ashf
no how would i go about doing that?
With PCC
Thommo
Genius
Performing a system repair using Pc Companion will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
ashf
ahhhh cant turn my phone on for long enough to do that Slightly_frowning_Face
Thommo
Genius
Your phone must not be switched on at all - Please read the guide again
Miller1323
You can use flashtool aswell if you have the ftf for your phone model. Just connect the usb to your phone holding volume down when it prompts you to
Miller1323
As thommo says phone must not be on. If your stuck at Sony logo it sounds like a kernel issue which is an easy fix
