it happen when I'm opening Snapchat and my phone suddenly froze and restart but then it stuck on the repairing icon. after a while an icon showed an image looks like a phone with an exclamation mark and then it turned off. I have tried the sony pc companion but there is nothing to do so I dont know what to do anymore. please kindly send a help?
@Phy wrote:
If that doesn't work then use Sony PC Companion to repair it.
http://support.sonymobile.com/us/tools/pc-companion/
The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
