water got into my phone after taking a couple of photos on the pool. i opened the micro SD/sim card slot and drained the water. afterwards, i dried the phone using a blower. i also tried opening the back cover so i can blow the insides. the phone wont turn on so i tried to charge it. the screen worked, LED lights lit and the phone vibrated 3 times after i push the power button. while charging, i tried to turn on the phone, pressed the power button+volume up button. the "Xperia - Sony" loading screen appeared afterwards, the charging status appeared (the one with the big battery picture). i tried to turn it on again but the same things happend. i disconnected it from the charger and tried to turm it on but it wont
The blower part was a bad thing to do,you could have damaged the circuits.Contact a close sony service:
i made sure i have not touched anything when i opened the back part to blow. i only took the back cover and thats it. everything was still intact including the battery. but still it wont turn on 😕
I still think the best thing you can do now is let a sony service handle the device.
He can try though.
i guess the phone is already all dried up. but im going to try anything to recover my phone. im now trying to reinstall my software :3 thought it may help because the phone turned on when i charged it (showing only the "xperia-sony" loading screen" and battery level photo).
You can try to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
done repairing the siftware using the PC companion. the software was updated but the phone still wont turn on 😕
