headphones not ditected after update Xperia Z2
Sannalarsson
After I updated my phone to lataste version mycket phone doesn't find my headphones.
My headphones work fine in other divices and I have tried other headphones to..
I have cleard all data from smartconnect and uninstall and re install it, but it doesn't work..
15 REPLIES 15
profile.country.RO.title
_alexdon_
Have you tried the sound enhancements suggestion? If still not working,you may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
dandy63
Leader
@Sannalarsson The Headhone selection feature i mentioned is a new feature that was added with the 4.4.4 update......for instance i use Marley Headphones & have to select General in the selection.
Worth a try.......if you do a quick search thru the Forum this Headphone detection problem since the last update seems to be affecting quite a few people BUT not everyone, follow @alexdon advice & try the repair but do a search of other peoples posts also & have a read of possible solutions :smileysmileywink:
Sannalarsson
I don't find sound enhancements so I have'nt been able to trie that suggestion Slightly_frowning_Face
Sannalarsson
ok! Will be back and tell if something of this has worked 👍
Sannalarsson
Have done the software repair and it's still dont work.
On headphone settings I have on geniral..
_alexdon_
In this case,you should have the device examined at a sony service:
alexdon
