On my Z1C I have noticed in the last few days that when I plug in eaphones, the sound still comes out of the speaker and not the headphones.
Sometimes, plugging and unplugging the earphone a few times fixes the problem, sometimes it does not.
However, rebooting the phone always fixes the problem - for a while at least anyway. But once I disconnect and reconnect the problem can occur again, until I reboot.
The fact that reboot fixes the problem suggests a software/firmware issue rather than hardware - does that make sense? Also, I dont recall ever having this problem before this most recent firmware upgrade which I only applied a few weeks ago.
I did a search on the forum and see someone else reported this too, but it was dated before the latest firmware release - which does not make sense to me.
Anyone else seen this since the latest firmware?
Thanks!
Thanks Jake,
I will give that a try - I must have forgot to tick the subscribe option so I did not see your replies.
I have been rebooting the phone to get round the problem as I did not fancy being without it for 7-10 days if I had to send of for repair.
Next time it happens I will try your suggestion and see what happens. Shame you support colleague I spoke to did not suggest that in the first place - her only solution was to do a Software Repair or post it in for physical repair.
Will let you know if your suggestion works for me.
No problem Harryw66, I hope all goes well.
Hi Jake,
I forgot about this because my phone was pretty stable for a few weeks after my post.
The earphone problem started happening again so I came back here and saw your post again.
I have just checked the phone and Smart Connect was actually Disabled.
So, should I Enable it and then clear app data next time it happens? Or given that it was Disabled all this time - should it even be a factor in this problem?
Thanks!
