Dear Sony team
I would like to take this opportunity and wona say thanks for making such a nice device.
What I like most is the battery life it gives me I can easily get thrue Al most 3 days in normal usage...
In last word thank you thank you thank you very much....
means there is no solution as of now for this issue?
That means there is a coding issue
Now if i am not wrong then stamina mode uses battery states to measure remaining timings
It might be calculating the reaming battery time by the calculation of battery drain between particular timings
So if I am not wrong and if this is not done then this should be a solution
coding for battery drain and certain timing calculation is set in side the program but if i am not wrong then the reverse states coding is missing
if we go back step and do a minor coding by adding some recharge battery states and re time calculation as soon as batter start getting recharge then it might be possible this could be the same way as the states bar battery states in % is showing when we are not charging it decreases and when plug in it reaches to 80 90 or 100
Above is my logic I might be completely wrong
Hi Jay,
What I meant to say was that its not a coding issue. May be Sony, Lenovo and othe rmanufacturers want it to work like that only. Below is my analysis:
The software keeps on tracking the usage stats of the user as to how much he listens to music, watches videos, download data, screen on time habits of the user etc. All in all, the software captures user specific stats to analyze for a given user how much time exactly he battery would last in relation to user battery usage behaviour.
I hope you understand. This is the reason I say its not a bug rather it is working as designed.
-Arpit
thanks buddy
