GPS problem, not any signal!
kenaney
the problem is that i cant use my gps (tryed several gps apps, sygic, google maps, ), it finds sattelites but cant position me or my route and if i leave him for searching my positvion after a while my phone gets hot.
what i tried so far:
-restarting phone --> didnt help, wel once but after a minute lost that signal again
-flight mode on or off --> didnt help
-wifi on or off --> (if it connects to a wifi it works but still no gps signal)
-roaming on or off --> didnt help
please help me to fix this problem, i am most of my time on the road these days and surely need somethimes assistance on road (im on vacation in france btw)
PLEASE HELP
105 REPLIES 105
pradeeprk4
Are you sure? because I am going to give my phone in service center for replacement in a few days.
should I wait till ICS release?
Bardia
Thank you for answering us. I'm waiting For ICS and GPS Fixed Slightly_smiling_Face
kenaney
dear Oskar,
what i understand from ure answer is dat gingerbread is not compatible with the sony gps hardware on the phone because ure having enormous people complaining about it.
People what i tryed so far:
-updated my phone to the latest update available, i believe the one with 84 ending. It was awfull, battery drained like nothing, got lag. Something i found out about battery drain was if u set up an Alarm for a day or two, ure battery drained 3x quicker then before. If u dont believe me, try it ureselfs. GPS didnt work also with this update.
-the above problem was worser then the one i was complaining about and the only solution was to get back to the previous software. Went to the dealer i bought from, they said i had to wait several weeks for repair. I couldnt wait that long so repaired it myself by rooting it and flashing the old rom back. Battery drain did fix, but got another poblem that i havent got before. Signal drop......
-Now im on the original rom the phone came to me, im "happy" with it while still not able to use GPS....
CAN U GIVE US AN DATE FOR THE ICS UPDATE PLEASE!!!!!!
Gaming
I got problem with the GPS too i takes a lot of time to connect if it connect.  I'm on .184 and for the first days it was connecting really fast. I repaired from PCcompanion still the same. Slightly_frowning_Face  the bad thing is that i really need the GPS
Bardia
GPS Developer promissed us it solve in ICS,Just wait afew day Slightly_smiling_Face
pradeeprk4
this is what typically happens when I try to use gpsscreenshot_2012-08-24_2034.png
more than 20 min, 10%  battery drop, 13 satellites in view, but still no fix(but fixed after 30 min)
Are you guys facing similar scenario?
kenaney
https://www.dropbox.com/s/gd53wsx2trs2nzi/screenshot_2012-08-24_1953.png
u got lucky cuz u got sat in range wich i dont get even one in 99,99% of any case
all i get is this
Bardia
what's your app's name ?! that you used ?! I wanna test it too
kenaney
gps status, search on google play
Bardia
Thanks, I will test it
