Hello... I'm using SONY XPERIA U
What can I do if I forgot my screenlock PIN?
Do I need to reset the phone?
IF reset is needed, how can I reset my xperia U at home?
AND I'm asked to type in my PIN password again and again,,,
Either this:
/t5/FAQ/How-to-unlock-a-phone-w-o-reseting-reformating-the-phone/m-p/927295#U927295
Or,if you do not have internet on your device,you need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
