Experia C3 dual
Nhlanhla
Experia C3 dual
Hi everyone I bought the Sony xperia c3 dual about 3 days ago. i switched it off last night to charge it and this morning i woke up switched it on and the screen keeps flashing. this has been happening for the past 3 hours. Please advise Thank you
3 REPLIES 3
Hampus
How do you mean that it's flashing? Does the phone not boot correctly? I suggest that you perform a software repair on your phone via PC Companion:
http://support.sonymobile.com/global-en/tools/pc-companion/
In PC Companion you press start on Support Zone > Start on Update the phone/tablet software > Repair phone/tablet (the blue clickable link in the message) > Follow these steps without having your device connected to the PC.
Nhlanhla
flashing screen meant as blinking screen
Hampus
You should try this software repair that I mentioned in my earlier post. Also make sure that your phone is powered off when doing this. You can force a shut down to make sure that the phone is off:
http://support.sonymobile.com/global-en/xperiac3dual/userguide/Resetting-your-device/
