How do you mean that it's flashing? Does the phone not boot correctly? I suggest that you perform a software repair on your phone via PC Companion:
http://support.sonymobile.com/global-en/tools/pc-companion/
In PC Companion you press start on Support Zone > Start on Update the phone/tablet software > Repair phone/tablet (the blue clickable link in the message) > Follow these steps without having your device connected to the PC.
flashing screen meant as blinking screen
You should try this software repair that I mentioned in my earlier post. Also make sure that your phone is powered off when doing this. You can force a shut down to make sure that the phone is off:
http://support.sonymobile.com/global-en/xperiac3dual/userguide/Resetting-your-device/
