Dropped phone, no response
W1
My phone is z1 and when i walk it drop on the ground i try to open it and it is not response itry to reset it and also not response and i feel it is very hot
what can i do ?
2 REPLIES 2
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
If the above fails,you need to contact your local sony team:
alexdon
@W1
If that doesn't work, contact your local Xperia care
