Hello! I've found the double tap to wake up to be very sensitive when the phone is put in my pocket, the screen unlocks on its own and sometimes the flashlight gets toggled.
I'm on the latest firmware.
Are there others who face this issue as well?
Have you applied a protective film and/or tempered glass?
As for the flashlight and the other "issues" while the phone it's in your pocket, most likely you are pressing the physical camera button w/o realizing it.
ok then, there's nothing wrong with your phone, just that double tap to wake up works really good.
what if you keep the screen away from your leg (if you keep it in your pocket) perhaps that might help.
That's correct but there's no other way around, unless you buy a protective case that has a screen cover.
