I just got an Xperia Go and are very happy with it, but...
It looks like the cover doesnot fully close and now I worry if it is watertight now.
Should I be worried?
Thanks,
Michael
Just apply a strong press on the front of the cover where it appear that is not closed well u will hear a sound and u will feel that it stucked where it should be..
The problem that stays is that when I press the back the side (with the earphone jack) opens up again. That side just does not really seams to close.
Any tips?
I have the same problem, on the bottom and close to the volume rocker the cover is not fully closed. And of course, water gets in to the back, but i saw some review and they said it is normal to get some water in the back.
So is this a production problem? Should we complain with Sony or go to a Sony Store?
You can plunge it to water even without back cover. Back cover is kind of decoration here
Hi
same problem here
minutes after opening the brand new Xperia go
I noticed the the side with the volume buttons will not close fully,
what Else should I expect in the phone.
I have Xperia Ray and it is a very well built little mobile
disappointed !
I was having the same problem but then I knew how to close it:
first step:
make sure that it stucked from the start of it.
2nd step: aply a strong pressure by ur fingers on it inward
last step:while u r pressing inward move it downhile:
U can see that it is fully closed the problen is not from the cover
It closes, but after awhile it "opens" again...
But if what @Agnes says is right, i see no problem...
