my T715 is continuously facing connectivity problems because of sony standard port most of the times first headphones stop working and then charger.what should i do with it to cure this problem?And do all the se phone have this problem?
The contacts on the fast port socket can get quite dirty, so wipe them with a soft cloth and see if that makes a difference.
The sony connection port is a real pain. Like Rishabh, I found that first of all I couldnt use head-phones, and in the end I couldnt charge the phone. I partially solved it by buying a new port from ebay and taking the phone apart and fitting the new one. It didnt last long however and I had to get a replacement phone from Ebay. Pretty bad design really. I think its caused mainly by trying to put the charger in to the slots up-side down and forcing it.
