Hi everyone..
I'm using my Se X8 for about 3 months now. They give me the phone with just 8Gb SD Card. I has install some games either from the market or through the web but somehow my phone suddenly cannot detect my SD Card. On the status bar it stated 'Remove SD Card. Insert a new one". Why this is happening? I've tried to check the card through computer and all the data still there. I've format the SD Card with fat 32 and recheck again. I've install back all the application in the card which I has back it up earlier. Through my computer the card is fine. When I insert it to the phone, is says the same. What should I do?? Someone plaese help..
I would try to repair the phone with either PC Companion or Update Service
just remember that it will delete everything stored on the phone
This could be related to a software issue on the handset, I suggest performing a software repair on the handset, as this may resolve the issue.
PC Companion:
I've done it but the result is the same. Is that because of the card or because of the slot at the phone? I've tried with lower memory card, ie. 2Gb and its ok. Hence the 8Gb SD Card is just wasting my investment. Argghhhjkhhh.
I've tried and tired. 2 of my 8Gb cannot be use anymore with the phone. Now I'm using 2Gb only. Any solution?
ive had this problem before with a 4gb card. this happens when i accidentally pull the usb cable while card is "mounted". be careful to check that before u pull ur usb cable. also this happens when u use a poor quality sd card. i know becaused i accidentally pulled the usb cable again on a new sd card but it still worked. the brand im using now is imation.
