Since updating my D6503 to Lollipop 5.0.2 (Build 23.1.A.0.726) yesterday, I can't connect to my workplace's Wi-Fi anymore. I'm still able to connect to my home and public Wi-Fi networks.
My workplace network settings:
I am able to connect to this network using my credentials on other devices - but my Xperia Z2 just refuses to establish a connection. I've tried "forgetting" the network, restarting the phone (including in safe mode). No success.
Is anybody else having this problem? And is Google or Sony working on fixing this?
-- Hayden
I'm not an expert in WiFi security settings, but if you open your WiFi settings page and tap on the 3 dots on the top right corner, go to Advanced, you'll find some settings to play with. Can you try for example "Auto IP support" on?
Auto IP support = Off (attempted to connect when "On" but this was not successful)
Passpoint = Off
Keep Wi-Fi on during sleep = Always
The phone attempts to connect to the network and it says 'Connecting' under the network name. Eventually it just times out; no error messages appear.
Do you have the possibility to restart the router? Just to see if this simple thing can help. Have you tried to add/connect to the network manually via Settings > Wi-Fi > Menu button (three dots) > Add network.
My experience has been that Lollipop is a lot more stable that KitKat for WiFi connectivity on my Z2.
Under KitKat, my phone would spontaneously disconnect from the office WiFi network at least once a week. I would need to toggle WiFi off/on on the phone to get it to connect again. That hasn't happened (yet...) on Lollipop.
