After alot of testing and doing, i noticed that there's one thing that gives too much lag and stutter while scrolling. The call log, which is found in the phone app. If this is filled with 40 or more rows of information, scrolling through this becomes really laggy and stuttery. This is also one of the main functions of the phone, so i hope this will be fixed in future updates! Or do you guys know a way to get rid of this lag without any update or something?
Thanks for answering!
Did you try until now to clear data for phone app under settings-apps-all?
Yeah, i even installed a few different kinds of roms. With the latest 761 i noticed that the phonebook and gmail etc scroll very smooth. Which they didn't in 757. But the call log is the part that gets really stuttery if it's filled too much, even in 761. I don't get that, because most other apps with more detailed lists have no problems at all with scrolling, except for offcourse the badly optimized ones.
I do not delete my call log but really hadn't noticed severe lag.I guess sometimes it does lag a little when scrolling.
Hmm, what can be the cause of this then? I didn't install that much other apps. Or maybe it's a setting which makes it better?
Could you be using task killers?
Not at all. I use greenify to hybernate some games and apps which i rarely use, just like i disabled most of the bloatware.
Did you also check in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Yeah, that makes not much difference. Does that mode turn all 3rd party apps off? Or does it do more?
It does turn off the 3rd party apps,you stay with default only.That usually helps in finding 3rd party apps responsible for lag,sudden shutdown etc.
