Bug Fix / Wish List
huggons
Member
Bug Fix / Wish List
How about to have an official bug fix / wish list here on the forum. Forum users to add their bugs and suggestions for continuous improvement to the Arc handset for the benefit of all Arc users and Sony!
Come on Sony forum reps, have you learnt from the past, are you up for the challenge?
I can kick things off with the following
Bug Fix / Wish List for next update after 2.3.3
Add support for BBC iPlayer downloads - support WMDRM10 or OMADRM2
Bug with user guide - Sony ref 90434693
Bug when connecting with PC companion, handset/PC companion reporting different battery levels - Sony ref 90430880
58 REPLIES 58
huggons
Member
my colleagues xperia play is on the 3 network and has the "missed call" bug/issue
Johan
As I posted above I'll be monitoring this thread closely but for monitoring reasons I'll mark this thread as assumed answered.
But I'll still get notifications when something happens in the thread, so no worries.
jlmcr87
One more suggestion:
When you take a photo, the numeration begins with 1,2,3,4............. But when you take the photos out of the phone the numeration is reseted and begins other time by 1,2,3,4.....This way you have the old and the new photos with the same numeration. Can you fix this numeration problem?
huggons
Member
Bug
Software Update/Update now (WIFI and mobile networks)
Could not update/Could not connect to network
Bug
video tutorials
xperia arc managing m...
views 0
unable to play/view
and
xperia arc battery life
views 0
unable to play/view
Let's keep the ideas and suggestions coming...
I would really love to see smart dialling in the default dialer/contact app, just because of the looks, and of course the integration.
Right now I'm using myDialer lite.
slimshaddy
Hero
I dont want to use appplications which shud have been a basic to this phone..
i mean we cant chose alarm ringtone..how sick is that Neutral_Face
and when the alarm rings its awful,,it's not gentle,,
for this m using alarm clock plus..
we cant make a call just by 1 touch or swipe..
thers no option for repeating the same song..
the point is that i know market applications solves this problems but also since these have to operate 24 hrs they use significant amount of RAm space and battery..
I recently replaced my SE X1 with an arc.
Time & Date settings are set to Automatic (Use network-provided values)
When travelling from The Netherlands to another timezone the arc is stuck on Dutch time instead of switching to the new timezone.
I travel a lot and I would really like to see this fixed.
(This problem did not occur with the X1, same SIM-card, Vodafone.)
Perhaps I'm understanding you wrong...to set the alarm ringtone open the Alarm app, select the alarm you want to edit (or create one), then select "Ringtone" to choose.
slimshaddy
Hero
Hmm..i see it now:-D but still there are many more featurea..like no stop watch 😛   I dont want to download apps for these basic func..and there are many more probs in this forum.. I mean basic  things that most of the users.wanted in the phone
jlmcr87
I updated my bug list to the firmware 4.0.A.2.368. This is what i have notied with this firmware:
-When you call in GSM mode only, the sound is choppy on calls(breaks in sound). In WCDMA does not occur. This problem is much less than in the previous firmwares.Please sony fix it completely!!
-When you are connected to wifi and hold the phone with the hand over the sony ericsson logo, the signal strength decreases and if the signal is weak it disconects.
-When you end a call, the call timing is not shown.
-Still not automatic brightness option in the menu screen.
-The crt effect when you power off the screen doesn´t adapt to landscape mode.
-The sound recorder is on the phone but there is no shorcut to it.
-When you put a direction into a contact, when you are seeing the contact and push the direction a Force close occurs: proccess  com.sonyericsson.infiniteview
-When you put images to the contacts of the camera album, when you sinchronize with gmal account the images of all the contacts gets very small. This does not occur with previous firmwares.
- (Suggestion) Make an option in   the  bluetooth widget to make visible the bluetooth,  otherwise if you   use  the widget you have to enter in adjustments to make it visible for  a   few seconds making the widget useless.
-   (Suggestion): More widgets in the launcher  screen off,  flash on/off, battery % and so on. (Like  the app   extended controls).
-(Suggestion): Possibility to select the compression or quality of the photos taken by the camera.
