Bluetooth headset doesn't work with Xperia MIRO
geletus
HI I've tried with some bluetooth headset with the same results with Xperia Miro: they connect to Xperia Miro, I get audio but the micro doesn't work: i have to use the micro of the mobile.
Those devices works fine with other mobiles, so I know the issue is on the Xperia Miro.
Any though on this?
thanks
5 REPLIES 5
Samuel1
Hero
Sounds strange. What kind of bluetooth headsets have you been trying out?
geletus
Hi, the headset is a Plantronics M55
I was aware the issue is when you make voip calls ( viber,line or anothe ims client)
Do you know how to fix this?
many thanks
Samuel1
Hero
So, you tried just voip calls and not "normal" calls? Not sure about the compatibility regarding voip calls with this headset. Could you try making a standard call and see if the microphone works?
geletus
Yes, a standard call works, but the micro doesn't work with a voip call.
Do you have any experience with any bluetooth headset that support voip calls with the Xperia Miro?
thanks
Samuel1
Hero
As far as I know most A2DP headsets (like MW1) works, but it also depends on the voip client you are using.
