Battery only lasts for 8 hours
JK15
Is it acceptable that the battery lasts only around 8 hours with normal use?
38 REPLIES 38
1adrian1
A brand new device will take at least a week of using and charging before it even thinks about reaching its maximum performance.
Rickard
@Wolfman_FR
Could you test if this also happens when the phone is in safe mode?
Do you have an SD card in the phone and if so, could you also try to remove this and see if that helps?
profile.country.fr_FR.title
wolfman017
I think I found which application was draining the battery. It is "La Poste", which was actively using the localization. I uninstalled the app, and I have no more battery drain on "Android OS".
I have to check Spotify now, which is consuming a little too much, but is not specific to the xperia X.
Rickard
Glad to hear that you found the app causing it and thanks for letting us know which one Slightly_smiling_Face
Overmark
Hi all, snce some updates Saturday/Sunday my battery startet to drain within about 5 hours even in stamina-mode. After a simple restart of the phone it looks like the battery is back to normail. Hope this is helpfull!
ykphuah
For more detailed information about what possibly drains your battery, you can try this
https://www.reddit.com/r/nexus5x/comments/3y8144/guide_finding_battery_issues_with_googles_battery/
It gives a lot more information compared to what you get in the Battery Stats, but some of it might be a bit technical to digest.
Maniaacos
What should be the "normal" % level that Android OS uses?
Been using Xperia X for a couple of weeks now and as i see it then the Android OS is draining the battery. It's been always between 30%-50%. Is'nt that a bit too much?
ykphuah
My android os is 11%.
Have you checked whether are there any accounts you have that is having sync problems?
sgiesen78
yep, please double-check background services, lagging apps etc. Consider booting in safe mode. Because this sounds really weird. Even with my havy usage the phone's battery last for two days.
Maniaacos
Does the Battery Stats app give enough info or should i really dig in to https://www.reddit.com/r/nexus5x/comments/3y8144/guide_finding_battery_issues_with_googles_battery/ ?
