On your phone
settings > power management > battery > check the top 4 items on the list > tap on each and check the amount of time and % of the battery they used
or take screenshots (press and hold power & volume down at the same time)
and post the links here
also make sure to post a screenshot of the graph.
I don't see anything wrong with it, it seems that you are syncing too many apps, are you using any of the following
antivirus
taskillers
battery apps
booster apps
sweepers
are you syncing facebook, email accounts, music streaming, etc ?
also perhaps you are auto backing up photos, or auto updating apps?
You should, it will smooth things out.
that is 20% in 2 hours, not 100 to 20 in 2 hours.
anyway it is still considerable fast if you are doing nothing. maybe remove the avg.
Removing avg wouldn't help, avg is automatically installed in every z3 device and if it would cause a problem everyone would complain and drain everyone's battery fast. However my z3 without doing anything except calls can take upto a week with the normal stamina mode on and wifi always on.
he can uninstall it, but if he repair his phone then it will show up again.
