Battery Draining While Charged
Zulfaz
i have some problems..
which is when i charged my phone,it drains it battery life..
and sometimes when charging the battery doest even go up..
please help me..
i using sony xperia neo l
10 REPLIES 10
profile.country.RO.title
_alexdon_
Download sony update service and repair your software:
alexdon
Jake-SonyXperia
Hi Zulfaz,
With the information supplied, I first suggest removing any new applications, as this is commonly a result of an application that is using to much resource, which results in the battery discharging even whilst on charge.
If you are playing a Game which requires medium to high resources, this will likely happen every time. However if this happens when not using the handset then it is likely an application running in the background.
Try the above first and let us know how you get on.
What are your thoughts about this forum? Let us know by doing this short survey.
Zulfaz
nope it doesnt change a thing..i tried it
Jake-SonyXperia
Hi Zulfaz,
Did you also try the Software repair on the handset using the Update Service?
Please let us know how you get on.
_alexdon_
@Jake-SonyXperiaSupport wrote:
Hi Zulfaz,
alexdon
Danial-mach1
Leader
Did you try to charge your phone when its off??
Zulfaz
i tried that also//
sometimes it goes up.sometimes it drain..
and if charged it never went 100%
i think about 60% and then it started draining again
Danial-mach1
Leader
try this one:
enter this code *#*#7378423#*#* in phone pad
then go to service tests>battery health test see what it write there
if says good no need to replace then as Alexdon&Jake said go for software repair by SUS
Zulfaz
i go to the service test but i dint finish the battery test because before it finish my phone has shut down, but it said the battery status was good.
i think my problem is the phone micro-usb plug is malfuntioning
