i bought my phone at 19.2.2014 since then i have used it normally ! but these last days i have this problem !android system drains a lot of battery ! please help me and i tryed flashing it again so no use !
How long ago?If it is very recently,you should wait some more because the phone will stabilise in a couple of days(even more).
@Theliako
You definitely have some app running in the background (see you app list), because from the screenshot it is visible, that something holds your system Awake for certain period of time.
My guess would be apps like account sync, Facebook, etc.. that have ability to run in the background (if not disabled!) without user interaction.
i flashed it 27-2-2014
well i tottaly agree with you but the fact is i dont know whick apps are they
I suggest you use it in safe mode for 1-2 days and see if there is any difference.
ok sir thanks ! if i notice difference how am i going to know which apps are so battery demanding and keep the phone awake ?
@Theliako
I use Clean Master to monitor junk and / apps running in the back and sometime to clean them, but there is app on Google Play called Wakelock Detector that can "analyse" some of apps running on your system, so it may be helpful to you detecting app that is draining your battery... (hopfully successful in your case)
EDIT: Or do what alexdon said. 🙂
As prometej-zg said,there might be a permanent syncing in the background.Maybe now you will see a difference.
thanksss !! i rememberred now that when phone drops to 80 or less android stopss draining so much battery ! and most times i spend nights not in safe mode nor in airplane mode ! and no battery is used for ex. i go to bed at 11 p.m and wake up at 7 a.m and stil to the same percentage !!
Ok,keep us updated through the process.Also,try to use stamina mode,it does help with managing battery life.
