I have a question ,
My Xperia SP Orignal Charger is 5V-850 mAh
is there a problem if i used 5V-1.5A ? or 5v-2.1A ? or it's dangerous ?
and they are orignal ( 1.5A is for Xperia ZL , 2.1A is for Sony Portable Charger 3500mAh )
So i need to know if it's dangerous or it's okay ,
( My Xperia SP Battery is 2370 mAh and Charger is 5V-850 mAh , it's taking too long time about 2.30 hour charging , and Xperia ZL battery is 2370 mAh and Charger is 1.5A, i think it's taking only 1.30 hour , and both of them have the same battery 2370 mAh but the difference is in the Charger )
Please answer me , and Thanks
If you use a higher amperage there will be no problem.The battery will just charge faster.But do not use bigger voltage,as it will damage your phone.
My Charger is 5 Volt so there is no problem if i used 5 Volt and 2.1 A Charger , alright ??
Sorry and Thanks alot
Yes,there should be no problem about that.
